I have a customer with an Ricoh MP 5500 copier machine, I can barely see the control panel.I think it's the lamp on the LCD broad.Can I buy the lamp separate? THank You
Ricoh MP5500 LCD Broad
Re: Ricoh MP5500 LCD Broad
http://www.copytechnet.com/forums/ri...urce-lamp.html
Please use Google search or the forum search, also check Goose's Guide.
its not easy n you might/will break a few...magnifying glass lite combo used on tech benches
will assist you if you decide to try this...good luckComment
