MP171 SC982
  • Voltage
    • Jul 2008
    • 282
    MP171 SC982
    Hi Guys
    I have a MP171 base machine that will every now and then go into SC 982. Localization error: Set SP 5807. I will then set the SP to the correct location setting and the machine will work, but the counters reset to 0 which is a big problem? I do not see any battery on BiCU board.
    Replace BiCU?
  • Tonerbomb
    AutoMajical Resolutionist
    • Feb 2005
    • 2589
    Re: MP171 SC982
    you have something zapping your NVRAM, that is where the counter is kept. Controller, BICU, or maybe a high voltage issue. Will it make a copy?
    Mystic Crystal Revelations
    • Voltage
      • Jul 2008
      • 282
      Re: MP171 SC982
      Yes, after i set SP 5 807 it works fine. It actually went into SC551 this afternoon. Could reset it. Took out all the plugs out of the BiCU and plugged them back in to reset it. It switched on again but then went into the SC 982 code again. I set SP 5 807 again and its working now.
      • Polarbear
        • Feb 2012
        • 1070
        Re: MP171 SC982
        Wonder if your nvram is not cooked - cause why else would it lose the settings?
        Press the GREEN button!!
        • Voltage
          • Jul 2008
          • 282
          Re: MP171 SC982
          Ja, Think so too. And now i have 2 MP301s that will freeze when its in energy saver mode and receives a print job. When you switch the machine off and on it goes into SC144.
          The joys of being a techie :-)
