MP3350 set scan default to PDF
  • copyaction
    • Oct 2007
    • 980
    Customer has MP3350 and the scanner is set to default to tiff
    trying to set it to default to multi page PDF but I don't see it
    under user tools, scanner features, send settings like previous
    models.
    is it somewhere else or am I losing it?
  • Eric1968
    • 2459
    Re: MP3350 set scan default to PDF
    Select the scanner-function. On the Touch Panel select File-Type and set this setting to Multi Page PDF and press OK.
    Press the key with the diamond and the arrow and select Set as Default and confirm the setting.
    • copyaction
      • Oct 2007
      • 980
      Thanks!
      • ruben
        The New Guy
        • Oct 2012
        • 1204
        It's all clearly stated in the manual.
        See: Specifying the File Type and Registering the Default Values of the Scanner's Initial Display
