Meter Reading Page with Contract details
  • Rajrajraja
    • Sep 2009
    • 31
    [Misc] Meter Reading Page with Contract details
    Dear All,
    I would like to add maintenance contract details in to Ricoh MFP, like Click charges, Contract Number, Minimum Billing Amounts,etc..
    Is it possible to get all the information printed in meter reading page all the time?
    Please suggest..
    Thanks & Regards,
    Raja.
  • mikadonovan
    • May 2008
    • 2931
    Re: Meter Reading Page with Contract details
    Originally posted by Rajrajraja
    Dear All,
    Please suggest..
    Thanks & Regards,
    Raja.
    User tools>system>admin tools>DIsplay/Print counter. This is a list of chargeable clicks.
    NEVER ASSUME ANYTHING
    • ruben
      The New Guy
      • Oct 2012
      • 1203
      With SP5-812-002 you can add a string to the bottom of the counter page, it can only be no more than 20 characters and can contain numbers and letters.
      • mikadonovan
        • May 2008
        • 2931
        Ruben, you taught me something new today. Im going to use that sp to make my job a little easier. Thanks, dude. Ill bump our rep for that one.
        • ruben
          The New Guy
          • Oct 2012
          • 1203
          Originally it is for facsimile details, so (depending on your language) will say "Fax to:" then your string. Mostly we use it for meter requests, sometimes adding the customers own machine ID.
          • mikadonovan
            • May 2008
            • 2931
            I am going to add the customer name to the end of the fax number. I input service data into our system from those sheets which come from every machine I service. It will keep things squared away if I forget to write the customer name on
            my sheets.
            • Rajrajraja
              • Sep 2009
              • 31
              my sheets.
              Thanks a lot to all of you, we use to feed our sr.center fax number using SP mode, As i mentioned on my first query, is it possible to get all the details to be printed in the meter reading page.
              We can feed click data, supply order details,breakdown call number,etc.. is it possible to get all the details to printed on the meter reading page?
              One more- is it possible to remove - please fax to...
              Thank you & Regards,
              Raja
              • ruben
                The New Guy
                • Oct 2012
                • 1203
                Raja
                No and no, you are limited to 20 characters maximum and it is not possible to remove the fax to message.
