sr 5000 staple issue
  • leo34staffs
    copierman
    • Aug 2007
    • 503
    [Misc] sr 5000 staple issue
    Hi guys.
    I have an sr5000 finisher that when stapling does not trim the staples on one side leaving a long staple "poking up" . I have swapped the staple unit assy and it worked ok........ until a few hours later. Anyone seen this problem?
    Networking skills are advantageous but use of a 3m vacuum cleaner is essential
  • Ramón
    • Mar 2011
    • 26
    Re: sr 5000 staple issue
    Originally posted by leo34staffs
    Hi guys.
    In the new stapler unit you put Guide - Standard Fence previous unit? if you put this can happen you say
    On the other hand, if the same phenomenon with both staple units maybe the problem is not what you have in them, but rather in the media in which it sits. Check sensors hidden in the back that give the stapling position.
    • leo34staffs
      copierman
      • Aug 2007
      • 503
      I have just been checking in the manual and i think i may have missed that!!! ( the metal plate guard) I swapped over the obvious parts like the solenoid etc but missed this!!!!
      Thanks for that (strange how it has worked initially)
