Problem Scan To Folder Ricoh MP5000 for windows 8
  • zulkepli
    • May 2025
    Hi everyone, recently i change my laptop to window 8 but i have problem when setting scan to folder to my laptop. Can anyone help me?? Tq
  • Eric1968
    • 2458
    Re: Problem Scan To Folder Ricoh MP5000 for windows 8
    SMB-scanning to Windows 8 is not possible at this moment. Ricoh wil release new Network firmware in June this year. There is a workaround for it. You'll have to make some adjustments in the registry.
    Disable "Secure Negotiate" on the client. You can do this using PowerShell on a Windows Server 2012 or Windows 8 client, using the command:
    Set-ItemProperty -Path "HKLM:\SYSTEM\CurrentControlSet\Services\LanmanWor kstation\Parameters" RequireSecureNegotiate -Value 0 -Force
    Note: The command as displayed above may wrap multiple lines in your web browser.
    • zulkepli
      Ok TQ. How about setting using FTP?
      • sandmanmac
        • 3964
        FTP is non-firmware dependent, and works great. I generally use Filezilla server.
        One inconvenience on your laptop may be that FTP uses IP addresses, so you may have to 'tweak' the settings from time to time, as you come and go with it
        • jtymabel
          • Aug 2008
          • 164
          ftp works great...even with macs once enabled.
          • zulkepli
            anyone can u teach me how to setting ftp in windows 8?? TQ
            • sandmanmac
              • 3964
              Let's keep it simple. Set up scan to email and be done with it. And there are at least 1346 posts about how.
              • zulkepli
                TQ so much
