Hey all,
Ive been fighting a new SR3090 finisher on a MPC4502 machine. For some reason it jams in the Top Tray but not the shift tray. If i run copy/prints to the top tray of the finisher after 10 or 30 pages it just jams, the odd thing is the paper jams and it takes a few seconds for the machine to relize its jammed, even weirder is the motor on the finisher keeps running but it bogs down and turns real slow like something is holding the transport rollers, i swapped the rear motors for the top tray and shift tray around since they were the same motor got the same result, so I thought maybe the one way in the bridge was slipping so i changed that cause they stop just as the exit the bridge and hit the entrance of the finisher, same result with that to, the whole motor bogging down and trying to run even after the machine is saying its jammed and stops everything else kind of seems like a firmware issue or something.
But if I run everything to the shift tray instead it runs just fine which doesnt make sense because the entrance sensor, bridge, and transport roller system all has to run to drive to the shift tray so you would think it would jam there but it doesnt. I also notice when running the shift tray the motor is like full on, but to the top bin there is a different timing cause you can watch the belt gears and you can see after each sheet there is a very slight pause but it keeps that rythem until it jams and it usually does it right at the pause.
Anyone out there have info on the SR3090 I only have 4 of the 4502 models in my area 3 have a finisher and this is the first one ive had an issue with. I also did a firmware update but there isnt a finisher update only machine firmware since release.
