have a ricoh 8001 and i have notice J006 jams.I replaced two one ways,cleaned sensors,cleaned rollers and replaced the paper feed rollers and belt.It will jam with one sheet.The paper stops right before the last sensor,but not on it,before it gets to the white transport belt.some time i can get alot of papaer thru the feeder then i can run 10 and jams.
ricoh 8001
Re: ricoh 8001
You said you cleaned the sensors but did you clean the registration sensor. It is under the guide plate and points down. I always forgot about it because it was under that big guide. If you did clean it did you see this TSB?TSB 030.pdfTotoro -
Re: ricoh 8001
yes i cleaned that sensor it stops just before that sensor.i looked at that TSB and when i look at the doc feeder it doesnt look like what i got.i do have the service manual and parts manual for this copier.just wondering if i have to just take the rear drive apart and clean everything.thanks for the imput.Comment
