Ricoh 2238c paper tray 1 and 2 exit jam do my head in!
  • alyeti
    • 13
    [Jamming] Ricoh 2238c paper tray 1 and 2 exit jam do my head in!
    Hello again its the 2238 again, anyhow trays 3 and 4 work fine, swapped 3 to 4 and didnt make a difference, obviously cant swap tray 1 with anything
    also did the mod on the trays in case it was something to do with that add paper tray problem ( not that its the problem)
    Anyhow i can see the paper picked up and try to leave the tray and then stops
    tryas 3 and 4 work fine only trays 1 and 2 have this problem
    Ricoh 2238c (DSC338 Gestetner)
  • rich2764
    • Jun 2009
    • 20
    Re: Ricoh 2238c paper tray 1 and 2 exit jam do my head in!
    does the display match the orientation and size of the paper loaded in the trays? Check in user tools that the trays are set to auto detect and then try the paper landscape instead of portrait etc.
    • Polarbear
      • Feb 2012
      • 1070
      AlyetiI checked the manual and see that there is only one paper feed motor. Which means that all the trays are driven through clutches.Have you swopped the paper feed stations of tray 1/2?Sounds like a bum clutch on the 1st paperfeed station to me.
      Press the GREEN button!!
      • JustManuals
        • Jan 2006
        • 9865
        This Parts & Service manual can now be purchased for $12.77 and downloaded immediately after payment from:
        Paul@justmanuals.com
