set counter key
  • montana
    • Aug 2008
    • 392
    set counter key
    hi....gestetner dsc445 aficio...keep giving me this message<to use the following functions set key counter >
    any idea please
  • TonerMunkeh
    Professional Moron
    • 3865
    Re: set counter key
    User tools / system settings / administrator tools / key counter management / set all to OFF.
    Hit it.
    • KenB
      Geek Extraordinaire
      • Dec 2007
      • 3944
      Re: set counter key
      Exactly!
      This machine had an external mechanical counter installed at one time, and was removed.
      • montana
        • Aug 2008
        • 392
        Re: set counter key
        hi...i followed the steps ....but when i enter the key counter management it is giving me the same
        message ...how to set all off?thanks for help
        • oldschool
          • Mar 2007
          • 245
          Re: set counter key
          UN-selecting the option turns off the key counter control for that option. This could also be set in SP5 113 you should go there and UN-select anything there.
          Jamex Tech Support: Saving the world one phone call at a time.
          • montana
            • Aug 2008
            • 392
            Re: set counter key
            hi...thank you for reply oldschool...but how i can execute the sp5 113....thank you for help again
            • oldschool
              • Mar 2007
              • 245
              Re: set counter key
              If you can't use the service modes then go back to user tools / system settings / administrator tools / key counter management / external charge unit management and unselect all of those options. It should have the same effect as turning off SP5-113.
              External charge unit management may be under Key op tools.
              • montana
                • Aug 2008
                • 392
                Re: set counter key
                hi..thank you mr oldschool....i will try it and feeback
