Ricoh MP 4500 fax forwarding
  • Rick
    • Mar 2007
    • 277
    When setting up fax forwarding is it possible to set the machine to forward only to an email address without printing the fax at the same time ? If so what is this called and where do I make this setting ?
  • sandmanmac
    • 3963
    Re: Ricoh MP 4500 fax forwarding
    That has been covered here many times, but again, it's user parameter Switch 11 Bit 6
    0 = Off (do not print)
    1 = On (print)
    (same for all machines)
