4502A High Freq noise
Re: 4502A High Freq noise
I seen the white idlers on the older models create some squealing noises. These are on the upper cover. Not sure if the '02's are the same. Then again may be just a NZ problem.... -
Why don't you just pull the covers from the ADF and pinpoint the culprit?NEVER ASSUME ANYTHINGComment
