how to disable scanner report (scan to folder ) ?
  • stupidkiller
    • Oct 2011
    • 57
    once I scan the document to folder,it will automatically print the report out,how do I disable the report ?
  • stupidkiller
    • Oct 2011
    • 57
    Re: how to disable scanner report (scan to folder ) ?
    thanks for your reply, but this is not a report, this is history , I want to turn off the print out report from wasting my paper. any idea ?
    • teebee1234
      • Jul 2008
      • 1670
      I've never seen a report print for a scan to folder job. What does this report show, or better yet post a sample.
      *Between you and me, if you meant to say a fax confirmation report then I'm going to kick your ass.
      • tomartronica
        • Jun 2010
        • 5
        Originally posted by HDSB
        Exactly what i was thinking!
        Can anyone please tell me how can i enable scan report on this machine ?
        • barratec
          • Jun 2008
          • 162
          Are you sure that is a Ricoh machine? Which model?
          • tomartronica
            • Jun 2010
            • 5
            nop, not sure..
            my opinion is that ricoh copiers dont print scan reports, only journal (history)
            • ZOOTECH
              Senior member of CRS
              • 3374
              Ask the OP.
              • duane@pbbsinc.com
                • Mar 2011
                • 77
                This post is pretty pointless without a model number for copier.
                Usually the auto report printing on most Ricohs are fax soft switch generated.
                Not sure but could he be using scan router v2light? There might be a setting for a report on that software.
                He needs to provide more info.
