MPC2800/3300 display dead mc tries to start (SC202) - SOLVED!
  • Herostrat
    • Oct 2012
    • 220
    Re: MPC2800/3300 display dead mc tries to start (SC202) - SOLVED!
    I had this on few MP5500,and it's never a polygon motor.
    It was problem with power supply usualy.
    Also defective power supply gives SC 672 sometimes...controler board can't comunicate with operation panel...it can't because it's not powered on propper.
    • Herostrat
      • Oct 2012
      • 220
      Me and my big tongue...I got a call for sc 202 on MP5500,I'm supposed to go there tomorow.
      Now machine we did with this code was in our workshop and it had defective PSU power supply unit...black screen,sc 202...the whole shabang,after that another machine was fixed by my colegue who allso changed power board and solved it.
      Now after reading the SC202 posts in here and some service manuals it does make me wonder if customer has THAT exact problem...defective polygon motor and bicu board.
      I haven't seen machine yet but before I go there I'd inform myself more on this...it will be field work without safety and comfort of our workshop.
      I don't know what is actual BICU board...all i found in service manual is BCU (Base Engine Control Unit),are you guys refering to that board...the one behind the fusing unit,below the fan duct,to the right of the controller box,and abowe the PSU board?
      My guess is that is some ocasions Power Board culd operate in such way that it doesn't power up that BICU or BCU (now i'm confused about the name) so it doesn't power on the polygon motor.
        • 37652
        Polygon motor on the MP5500 connects to the IPU board. Thats the board under the exposure glass.
        • Herostrat
          • Oct 2012
          • 220
          #19
          • qbert69
            • Mar 2013
            • 1152
            #20
            Resistor Spec Info::Re: MPC2800/3300 display dead mc tries to start (SC202) - SOLVED!
            The resistor with the "0" on it is being used as a "fuse-able link", based on what wattage it allows/disallows, it will "pop" if it is over its limit.
            I learned this info from a fellow in the aerospace industry that does board work.
            Cheers.
            REACH FOR THE STARS!!!
            Konica Minolta Planetariums!
            • Gift
              • Mar 2011
              • 2459
              #21
              @Polarbear:
              Thanks for sharing this information - now I can't wait for the next BICU to blow up
              Is there any SMD resistor type to recommend - I found several types (wattage ratings/dimensions) with zero ohm - not shure what to pick
              • Polarbear
                • Feb 2012
                • 1070
                #22
                Originally posted by Gift
                @Polarbear:
                @Gift
                I just looked for a device with similar "ballpark" values as the ones surrounding the faulty one. Even at this stage, that repair is still working!
                Seems like these resistors are used as fuses, to protect the input side of the circuit.
                If memory serves, the replacement came off a bicu board of something like a mp2352 or thereabouts, as they share similar components and seem to have been designed in the same era (components wise).
                Press the GREEN button!!
                • Gift
                  • Mar 2011
                  • 2459
                  #23
                  thx for the update,
                  had a chance to get into this, too - I simply replaced the polygonmotor first and after the OP didn't came up I knew I had a faulty BICU. I simply placed "some amount" of solder over the faulty resistor to bridge that thing and voila - all fine. I'm aware that this means there is no fuse-like protection of the affected part of the circuit but with a new polygon motor I'm willing to take that risk (unlikely it will blew again considering the expected, remaining lifetimes of the machines in the field).
                  • Polarbear
                    • Feb 2012
                    • 1070
                    #24
                    thx for the update,
                    Gift, did you order the modified polygon with the new part number? Then you should not see this problem return. Ricoh maintains that the mod solved the issue.
                    • Richariri
                      • Dec 2013
                      • 163
                      #25
                      Originally posted by Polarbear
                      We found a tiny resistor (close to the lower right power connector [they all have a "o" printed on them in white] was burnt so that the "o" was not visible. Replaced the resistor and started the machine, and all is well.
                      you sir are my hero, I have been waiting for someone to identify the resistor and confirm that replacing it works.
                      I had to replace the entire polygon mirror and BICU in one go and would love to salvage the BICU.
                      Thank You
                      • Gift
                        • Mar 2011
                        • 2459
                        #26
                        Yeah I saw the bulletin and have a modified motor in stock since we still have some first/second-gen MPCs in the field.
                        • iluxa
                          • Mar 2017
                          • 5
                          #27
                          Excellent! Has worked, many thanks!
                          • iluxa
                            • Mar 2017
                            • 5
                            #28
                            @ Polarbear
                            Excellent! Has worked with MP C4000, many thanks!
                            • fshead
                              • 2378
                              #29
                              Sorry for the low res cellphone photo. Look for the black resistors between the large white power connector and the row of capacitors. They are black surface mount devices with a white "0" printed on them.
                              I am not sure about the value, but if you measure all of them with a DMM, you will find that the one (which is normally discoloured as well) will have a vastly different value than all the others around it.
                              That one you will have to desolder and replace with another good one. It is normally a good idea to change the polygon motor assembly as well as this causes the fault - and Ricoh has brought out a modified motor that is redesigned to prevent this failure in future.
                              Hope this helps.
                              I JUST did this repair on a unit that went bad 2 years ago.
                              didnt use a new poly but cked the solder joints on it b4 insttalling it."Resistor SMD code" from a bad mpc3501 bicu brd.
                              there are 20 spares on them but a pain to desolder cause they fly away wth any force and one can not see where..
                              • Oze
                                Ricoh Fanboy
                                • 1663
                                #30
                                Bugger doing component level fixes on an MPC2800..!!!
                                The machine is now on the "not supported" list from Ricoh and getting parts is going to be difficult shortly so I CAN understand the need for soldering and the like but I'd have sold them a new machine.
                                And damn this is an old post
