RICHO AFICO MPC 6000
  • copierlady
    • 338
    HEY GUYS. WORKING ON ARICHO AFICO MPC 6000. IT KEEPS JAMMING IN THE FUSER. THE PAPER LOOKS LIKE ONE OF THE WHITE PAPER GUILDS NEAR THE FRONT OF THE FUSER IS CATCHING IT. BUT I CAN ROLL IT THOUGH THE FUSER MANUALLY NO PROBLEM. IT JAMS EVERY SINGLE TIME BEFOR IT REACHES THE EXIT. DON'T KNOW THIS MACHINE AT ALL. I AM A KONICA GAL AND MY RICHO TECH SUPPORT BUDDY IS ON VACATION. CAN YOU HELP ME? THANKS!
  • jonezy999
    just one copy??
    • Feb 2010
    • 952
    Re: RICHO AFICO MPC 6000
    If you're lucky enough to have a complete fuser to swap for fault finding, then that's where I would start. You could also see if the jam is caused by all cassettes and paper sizes. Also I would check out the transfer\separation assembly, I think these use a charge at 2nd transfer, check that connection.
    I have not failed. I've just found 10,000 ways that won't work. ~Thomas Edison
    • TonerMunkeh
      Professional Moron
      • 3865
      What's probably happened is someone's ragged a jam out of it and pushed one of the stripper plates out of position. If you've got a manual for this beast handy, follow the procedure for resetting the pawls after belt replacement. It involves clam-shelling the fuser open and pushing two little plastic wedges between the pawls and the belt to set the correct distance.
      Hit it.
      • copierlady
        • 338
        Ok guys gives me a place to start thanks for the info. I'll let ya know if it gets me any where!
        • JustManuals
          • Jan 2006
          • 9838
          Paul@justmanuals.com
