This is becoming more and more frustrating,it used to be replace hot roller and hit the road,but since we got some "for use" shipment of hot rollers it's only headaches.
First of all to explain why "for use"...cause our customers simply don't want to pay for "real deal"...there is apsolutley nothing that can persuade them to do it,it's simply how it is and we have to deal with such clients.
We use 2 types of hot rollers
*Copygraf-named by our salesman (I suppose,it's not labeled) aparently cheep chineese sh***
*Integral-a fairly descent hot rollers with good price/quality ratio
So copygraf is working in one out of 10 machines,some of them are even damaged...imagine the look on my face the first time I unfolded it out of protective sheet on field.
It is somewhat good on smaller machines,and mostly used on machines such as MP5500 and above.
But the 35's and 45's simply won't acsept them,if it doesn't show SC 542 in the morning then it does incomplete fusing all the time or just in the morning.
Now Integral made it all dificult,cause those were the failsafe,they never failed us on any machine,it used to be damn fine hot roller...USED to be,we got new shipement and so far 5 out of 5 that I replaced did incomplete fusing.
From what I'we learned so far one solution is to Update firmware to v. 2.29 Engine
But untill we obtain firmware (a bit dificult story on that part) I'm looking for alternate solution or just an opinion about what culd be done
If I find time I'll try playing with SP1103-00* fusing idling in workshop but still idk what to expect of that on field.
Thanks for any advices.
BICU (Engine)
Version Title Symptom Corrected
2.29
SC541, 542 Fusing-related SC codes (541, 542) and/or
incomplete fusing occur when making copies first
thing in the morning (esp. in cold environments)...tnx copytechnetincomplete fusing occur when making copies first
