Double printing on a savin c-3528
  • auburn business systems
    owner/technican
    • Mar 2009
    • 46
    then i print the confg. page or any other page i get a double prints on the right side about two inch's in.
    changed the following parts.
    1. belt cleaning blade and roller (new)
    changed out the following from a good running machine in my shop!
    2. changed out the fuser
    3. changed out the Transfer Belt Unit
    4. changed out the black drum unit.
    HERE IS A COPY OF THE PAGE TO YOU IF THAT HELPS !
    none of the things i did made a difference.
    any help you can give me would be great
    thanks Howard
  • knightfall
    • Jul 2006
    • 633
    Re: Double printing on a savin c-3528
    it looks like it may be the black laser or the image process unit, have you tried force line adj.? try also reseating the memory dimms.
    good luck
    Get your facts first, and then you can distort them as much as you please.
