MPC5502 Quick Blow 125 ma Fuse in fuser unit
  • techspec
    • Dec 2008
    • 128
    Hi all
    Has anyone came across a part number from Ricoh for this quick blow fuse in the fuser which resets the SC544 error?
    I've seen many work arounds on here but was just wondering if Ricoh are supplying this as a spare yet?
    Checked all latest tech bulletins on line and parts manual and nothing popping out at me.
  • locodelacolina
    • Apr 2013
    • 7
    Re: MPC5502 Quick Blow 125 ma Fuse in fuser unit
    Originally posted by techspec
    Hi all
    • HP:guy
      • Feb 2013
      • 279
      Part #D144fuse.
      • Coptech
        worker drone
        • 460
        Part #D144fuse.
        That one is funny. It comes from Ricoh via Hytec and will cost you around $35 If the $6 version works, that seems to me to be the better choice.
        • TonerMunkeh
          Professional Moron
          • 3865
          The new hot roller assemblies come with the new fuse too.
          Hit it.
          • techspec
            • Dec 2008
            • 128
            Cheers All
            Got the fuse ordered and into stock
            • Imprestik
              • Aug 2012
              • 296
              Just run them with no fuse at all, that's what I do and works a treat
              • SargeNZ
                • May 2012
                • 263
                You need the fuse to reset SC5xx codes to make the machine believe a new fuser is fitted.
                • katash
                  • May 2010
                  • 221
                  yep!you need the fuse to reset the 5xx codes,i did fit one assembly but i cant seem to solve a noise problem when the unit is warming and after that the noise stops its like the pressure cam gear rotates more than usual,any ideas?
                  • SargeNZ
                    • May 2012
                    • 263
                    Did you happen to do an NVRAM reset? There is an SP mode for this that I cannot remember off the top of my head.
                    • techsass
                      • Dec 2010
                      • 248
                      Sorry, but I can't remember the actual SP# or what you need to set it to. It's the Pressure Roller timing I think. Anyway Ricoh did a firmware update about a year ago to fix it.
