Same song second verse
SC 998 is and application error.
We have 2 of these machines at same customers office.
First one came up with SC 998. Ended up swapping controller boards and the one machine which originally had the SC998 started running fine.
Before I ordered a $1K controller board though I'd check out if it was just the SD card. Machine was running fine turned it off swapped SD Cards.
Would not come up do there you go bad SD card at least...
Now here is the problem put the good SD card back in machine and now it won't come up. Just says wait then Process error message the restart
then SC998.
Other than Firmware which I will try tomorrow morning anybody got anything? I'm running out of hair...
then SC998.
