ricoh 2045,problem.
  • tullio
    • Feb 2012
    • 268
    ricoh 2045,problem.
    ricoh 2045, when printing, pulls more 'sheets from the tray. a print ok.
    replaced rubbers same problem.
  • mikadonovan
    • May 2008
    • 2931
    Re: ricoh 2045,problem.
    Try a fresh ream of paper. If no joy, you may have to replace the torque limiter.
    NEVER ASSUME ANYTHING
    • Jomama46
      • 2900
      Or the pf clutch may not be disengaging
      sigpic
      A+; Network +; PDI+
      • Herostrat
        • Oct 2012
        • 220
        Sepparation pad,swap papper cassetes to check that out.
        Gears,springs,clutches,sliders,connectors and electronics...who on earth can tell what's wrong with it?
