Aficio SP4310N
  • habik
    • 2013
    Aficio SP4310N
    Hi Guys
    New to Ricoh machines.
    What do I need to get Hotspot print running on SP4310N
    It came with HDD and SD card what else should have been in the package!
    Please help as I do only Kyocera and Konica! Haven't had call back from Ricoh tech support yet !
    Can this printer actually do it?
    Firmwares HERE
  • blazebusiness
    SanDiegoCopierRepair.com
    • 1250
    Re: Aficio SP4310N
    Originally posted by habik
    Hi Guys
    Here's the reference guide just in case you don't have it.Not sure if the 4310 is compatible with Hotspot but my guess would be yes.HotSpotEnterpriseUsersQuickRef.pdf
    • habik
      • 2013
      Re: Aficio SP4310N HOTSPOT SETUP
      Have you set up before hotspot printer or mfp?
      what would i need in order to register the product on the printeron.net site
      I used serial number for the machine
      changed the admin / password so I can enter it on to the registration form yet each time I try to get the serial number I get this message from the reg form:
      "Unable to locate the Printer Machine ID or MFP Certificate number using T1138861152. Please confirm the information
      on the Administrator Specifications label provided and try again."
      My question is where can I find the administrator specification label lol?
      Firmwares HERE
