Ricoh MP C2000 toner problem
  • kmtech
    • Sep 2008
    • 125
  • 41-willys
    • May 2010
    • 36
    Re: Ricoh MP C2000 toner problem
    did you try a differant toner bottle, could also be a bad pump
    • kmtech
      • Sep 2008
      • 125
      Yes both oem toner.
      • ruben
        The New Guy
        • Oct 2012
        • 1203
        Remove the pump and check to see if it is blocked with toner, may require a new pump and vacuum out (or replace) the pipe.
        • kmtech
          • Sep 2008
          • 125
          Thanks for your help and will check it.
          • JustManuals
            • Jan 2006
            • 9838
            Paul@justmanuals.com
