How to check sensor?
  • jewen25
    • Mar 2009
    • 197
    I am new to this Ricoh aficio,its alway Jam,in fixing area,my problem how to check if sensor its ok using service mODe,pls help to get in service mODe? Tnx
    ERROR HELP ME AND HELP YOU
  • teebee1234
    • Jul 2008
    • 1670
    Re: How to check sensor?
    First, please post what model and what is the jam code displayed on the screen. And is the copy just stopping at a certain point (before, inside or past the fuser) or is it exhibiting a mechanical jam (accordion pleats). By giving us the details, our experience knowledge base can quickly come up with the most common causes for your problem. It could be something as simple as the wrong orientation of the paper in the cassette, the mfp will throw a jam if the length measured during processing doesn't match up to what is programmed for the cassette. Seeing that you're not familiar with servicing Ricoh, it probably wont do any good to give you detailed service info.
    But the short of it is you enter SP mode (Clear Modes, 1, 0, 7 then press and hold the clear/stop key) go to Modes (5) and look for input checks. For detailed info you need to get a manual (hello Paul).
    *above is the method to enter service mode on 'most' Ricohs, some have different procedures.
    UPDATE:
    Dude, you posted the same request earlier today for service info on Konica here. It's one thing to ask for legitimate help on a device, don't be trolling for freebies because you're too lazy/cheap to get the manuals and training.
    Dean Vernon Wormer: 0.2... Fat, drunk and stupid is no way to go through life, son.
    • JustManuals
      • Jan 2006
      • 9838
      Paul@justmanuals.com
      • jewen25
        • Mar 2009
        • 197
        Originally posted by teebee1234
        First, please post what model and what is the jam code displayed on the screen. And is the copy just stopping at a certain point (before, inside or past the fuser) or is it exhibiting a mechanical jam (accordion pleats). By giving us the details, our experience knowledge base can quickly come up with the most common causes for your problem. It could be something as simple as the wrong orientation of the paper in the cassette, the mfp will throw a jam if the length measured during processing doesn't match up to what is programmed for the cassette. Seeing that you're not familiar with servicing Ricoh, it probably wont do any good to give you detailed service info. But the short of it is you enter SP mode (Clear Modes, 1, 0, 7 then press and hold the clear/stop key) go to Modes (5) and look for input checks. For detailed info you need to get a manual (hello Paul). *above is the method to enter service mode on 'most' Ricohs, some have different procedures.UPDATE: Dude, you posted the same request earlier today for service info on Konica here. It's one thing to ask for legitimate help on a device, don't be trolling for freebies because you're too lazy/cheap to get the manuals and training. Dean Vernon Wormer: 0.2... Fat, drunk and stupid is no way to go through life, son.
        thnks Dode for the the dramatics explanation, The mODel is RICOH Aficio 2022, its jam At B and C
        • teebee1234
          • Jul 2008
          • 1670
          Good Luck
          • Herostrat
            • Oct 2012
            • 220
            As they allready pointed out you need to invest more in your own buisness,obtain service manuals and tech bulitens...tell you a lil secret...most of those are posted here...just keep looking,you are investing time and/or money in yourself basicaly.
            Now about that jaming,indeed we need more info on where does paper stops...there are few simple rules about how to recognise some jams.
            If paper stops at same spot ewery time without anything obstructing it,that probably means casette isn't configured propperly,if not then then paper doesn't activate sensor,or paper "lags" on some sensor.
            That doesn't mean sensor is faulty...meybe on Canon but not on Ricoh,just clean sensors and if that doesn't help then swap it with same one in duplex.
            If it's the same then the sensors are working propper for shure and that means some assembly doesn't deliver paper on sensor in apropriate time...now for that best thing is to sit and think about it...cause it can confuse you for example sensor jam location doesn't actualy tell you that inverter cluch before it failed to activate...it simply tells you that sensor wasn't activated.
            Gears,springs,clutches,sliders,connectors and electronics...who on earth can tell what's wrong with it?
            • jewen25
              • Mar 2009
              • 197
              Originally posted by Herostrat
              As they allready pointed out you need to invest more in your own buisness,obtain service manuals and tech bulitens...tell you a lil secret...most of those are posted here...just keep looking,you are investing time and/or money in yourself basicaly. Now about that jaming,indeed we need more info on where does paper stops...there are few simple rules about how to recognise some jams. If paper stops at same spot ewery time without anything obstructing it,that probably means casette isn't configured propperly,if not then then paper doesn't activate sensor,or paper "lags" on some sensor. That doesn't mean sensor is faulty...meybe on Canon but not on Ricoh,just clean sensors and if that doesn't help then swap it with same one in duplex. If it's the same then the sensors are working propper for shure and that means some assembly doesn't deliver paper on sensor in apropriate time...now for that best thing is to sit and think about it...cause it can confuse you for example sensor jam location doesn't actualy tell you that inverter cluch before it failed to activate...it simply tells you that sensor wasn't activated.
              ok thnx for the help,i will wait the right guys to answer my question,tnx
              • Herostrat
                • Oct 2012
                • 220
                I was trying to explain to you that one doesn't realy need Tech mode to figure out what's going on with sensors.
                Clear Modes, 1, 0, 7 then press and hold the clear/stop key look it up under SP7504* or if machine culd print then print out SMC report SP5990*
                • Hansoon
                  • Sep 2007
                  • 3391
                  I sincerely doubt that YOU are the right guy for the job....
                  Hans
                  โ€œSent from my Intel 80286 using MS-DOS 2.0โ€
                  • cleardata
                    • Jul 2011
                    • 137
                    now i understand why he has a red mark! he deserves it!
                    • jewen25
                      • Mar 2009
                      • 197
                      I was trying to explain to you that one doesn't realy need Tech mode to figure out what's going on with sensors. Clear Modes, 1, 0, 7 then press and hold the clear/stop key look it up under SP7504* or if machine culd print then print out SMC report SP5990*
                      I am very sorry to HEROSTRAT and to other Tech., i think we have miss communication,maybe i am arugant to my post,the time i post i need and a hurry to solve that,tnx
