MP C2800 BLANK SCREEN
Re: MP C2800 BLANK SCREEN
Hi
Seeing that the BICU is already new, the next port of call would be the controller (judging by the sc code).
There are remote instances where a code is generated by something out of the way like a pinched wire or such, which was then caused by the tech or the customer (which no manual will cover!)
Have you checked (and re-checked) that all the connectors on the BICU and the controller are seated properly?
When does the code appear - at startup or as part of the startup or standby routine?Press the GREEN button!!Comment
yes i did and entered the serial no. i will did check for pinched wires before i fitted the bicu i have ordered for a new controller just crossing my fingers,will keep you posted!Comment
