Ricoh MPC5000
  • GeorgeBest
    • Jul 2009
    • 516
    Ricoh MPC5000
    HI,
    Got a weird quality problem on an MPC5000 !
    Only when copying duplex sometimes strange dots appears at the the end of the paper.
    See the pictures. Strange, because it is not on every paper, say twice on ten copies.
    Customer uses the book mode a lot and have to check everytime on these dots.
    Can't figure it out where its coming from, checked heater, transfer, edge erase margins etc etc
    Hope that someone give me an hint here
    Thanks in advance
  • skynetto
    • Sep 2012
    • 257
    Re: Ricoh MPC5000
    There is a techinal bulletin about this. Here it is in italian but understandable.
    • ruben
      The New Guy
      • Oct 2012
      • 1203
      Re: Ricoh MPC5000
      The same document, but in English.
      rd029057a.pdf
      • GeorgeBest
        • Jul 2009
        • 516
        Re: Ricoh MPC5000
        Thanks !
        • GeorgeBest
          • Jul 2009
          • 516
          Re: Ricoh MPC5000
          Hi,
          unfortunately, despite the PDF file, I've done all the instructions that the file
          said to do. But there is no improvement, contrary.
          hereby two new results after the procedure as said in the PDF file.
          Someone a clue . . . ??
          • Herostrat
            • Oct 2012
            • 220
            Re: Ricoh MPC5000
            Honestly those look like grease stains...meybe it's just the pics.
            Looks to me like we are still uncertain what is actualy causing it...try doing about 10 to 15 consecutive copyes...meybe even blank papers,and interupt it opening the front doors.
            Look at the pappers jamed inside,perhaps one will show you what's causing it,dust inside machine transfers on paper random...give it a few shots.
            Gears,springs,clutches,sliders,connectors and electronics...who on earth can tell what's wrong with it?
            • BLADE
              former propeller tester
              • 478
              Re: Ricoh MPC5000
              a wax drip in the fuser (from the toner) will cause a grease stain, only seen it once a few years ago
