Hello
I have a problem with c2550 internal finisher.
When i turn on the machine then running the inicialisation of finisher (motor check...) then the machine marks a Paper jam Code 248 and Sc 796.
The paper jam code and sc code means the belt roller position sensor or belt roller solenoid error.
The solenoid and sensors are good.
The all of sensors work good (check all with multimeter)
When the machine wake up form sleep mode marks this error.
The finisher door have to open and close, then the paper jam ceases, the finisher is inactive.
But, the machine works.
The firmware version of finisher is 00.040:10
The cabel beetween the machine and finisher is good.
I checked this finisher another MPC2551 machine, the problem same as
