Ricoh LP4000 DN - the toner is liquid?
  • wiedu
    • May 2011
    • 47
    Hello,
    i bought a toner for Ricoh LP 4000 DN, but one toner is liquid. But i thought that the toner for printers arent liquid they are dried.
    Or does the device use an another system?
    Thans in advance
  • ruben
    The New Guy
    • Oct 2012
    • 1204
    Re: Ricoh LP4000 DN - the toner is liquid?
    Never heard of an LP 4000, Lanier or actually a CL 4000? If you are looking into the tube, then the particles may look like a liquid because they are extremely fine.
    • sandmanmac
      • 3969
      Originally posted by wiedu
      Hello,
      Thans in advance
      Dude! Looking at your profile, you are apparently some sort of technician...and I use that term VERY lightly!
      Your question would be ridiculous enough if it were from an end user, but coming from a so-called technician, SHAME ON YOU!
      It's hacks like you that give the rest of us a bad name!
      I don't know what you bought, but it's offensive that you're even here asking the question!
      On top of that, you can't even provide the correct model number.
      Negative rep for you!
      • Hansoon
        • Sep 2007
        • 3347
        Ouch!
        Hans
        “ Sent from my Intel 80286 using MS-DOS 2.0
        https://www.copytechnet.com/images/smilies/biggrin.png
        • wiedu
          • May 2011
          • 47
          Ok, thanks yes it is ricoh CL 4000
          well, i take a look again and it seems that you are right...) thanks for your help
          • wiedu
            • May 2011
            • 47
            sorry, its the first time i bought the toner cartridge by ricoh, usually i only buy toner by konica etc.
            yes, it is call CL 4000 .. LP is the type of the toner cartridge
            • Eric1968
              • 2459
              Hello,
              Thans in advance
              Is that you, Aab1?
