Mp7500 sc991 sc834 sc998 sc672
  • mrwho
    Major Asshole!
    • 4299
    [Error Code] Mp7500 sc991 sc834 sc998 sc672
    Hello there, gang!
    This machine has given me a hard time with these kind of errors, and after swapping almost everything electronic on it with a known working machine, the problem got away after replacing the two 128Mb RAM modules on the vertical board at the back of the machine.
    Now, roughly 3 months later, here it comes again. What are the odds of these DIMMs being bad again? I have no other DIMMs at hand to test it out, and I'm not so sure now that the DIMMs solved the problem in the first place.
    Any hints?
    I need a vacation!
    [Vacation Time Countdown Mode: ON]
    Mascan42
    Ibid
  • fshead
    • 2376
    Re: Mp7500 sc991 sc834 sc998 sc672
    did you try cleaning the contacts wth a pencil erasure and then alcohol?
    i would take a pic of the mem chip and try to pick one up locally..google the info on chip
    \probably same as a laptop memory and not as costly as buying from ricoh....
    good luck i hate when i get these fixed problems reappearing.
    • mrwho
      Major Asshole!
      • 4299
      Thanks for the prompt feedback.
      I did clean the memory contacts before starting this thread - with a pencil eraser only, not with the alchool though - but nevertheless, as the problem remained, I replaced the DIMMs with ones from another working machine (that I managed to find) to no effect.
      I tried to remove the printer/scanner option (SDCARD + Extra DIMM) and left the machine working as a copier only, to no avail. The customer tells me the machine takes ten or fifteen copies and then crash-lands with a SC672.
      Mascan42
      Ibid
      • TonerMunkeh
        Professional Moron
        • 3865
        Could be a firmware glitch, have you tried reflashing it?
        Hit it.
        • JustManuals
          • Jan 2006
          • 9838
          I've got the manual if you need it, no charge.
          Paul
          • mrwho
            Major Asshole!
            • 4299
            Paul
            Thank you, Paul! I'm covered! Thanks for offering!
            Mascan42
            Ibid
            • seansbar
              • Dec 2010
              • 198
              Try another Hard Drive
              • mrwho
                Major Asshole!
                • 4299
                Thanks for the tip. I forgot to mention - my colleague put in a new HD before I took the machine.
                Mascan42
                Ibid
                • skynetto
                  • Sep 2012
                  • 257
                  Nr. 103 on the PartsCatalog Electrical Section 1.
                  p.s.: SC672 we get even if the swith on the fax board is not set to on.
                  • mrwho
                    Major Asshole!
                    • 4299
                    Originally posted by skynetto
                    [ATTACH=CONFIG]21409[/ATTACH]
                    Thanks for the tip. The reason I swapped the memories was because I also noticed those codes to be closely tied with them.
                    Now the EEPROM is something that never had ocurred to me. Anyone knows if this EEPROM is used on any other model?
                    Mascan42
                    Ibid
                    • mrwho
                      Major Asshole!
                      • 4299
                      Originally posted by joker
                      Did you find any solution? I have the same error code 672 from time to time...
                      Although ultimately I wasn't the one who fixed the machine, I believe my colleague finally solved it by replacing all the memory dimms.
                      Mascan42
                      Ibid
                      • qbert69
                        • Mar 2013
                        • 1152
                        Can't remember what model of machine it was, but we had a machine that was throwing random SC codes (don't remember what they were) at a particular location. What it came down to, was that the wires to or between the various control boards were zip tied too tight and were getting crosstalk between the wires with the control signal pulses and causing the random error codes. Once the zip ties were cut and the wires loosened and separated, the random error codes disappeared. I am not saying this is the solution, but it could be. YMMV!
                        REACH FOR THE STARS!!!
                        Konica Minolta Planetariums!
