Wavy lines on a C5000
  • Jomama46
    • 2900
    Black copies look good. Color copies are not overlapping. Good density on all colors. When I run a cross hatch pattern, the lines are wavy, in addition to being out of sync.
    Replaced the ID sensor, replaced the ITB belt, no change. Line position adjustment reports "not complete" and Hidden SC is 285.
    What the heck?
    sigpic
    A+; Network +; PDI+
  • mikadonovan
    • May 2008
    • 2931
    Re: Wavy lines on a C5000
    Sounds like the next step would be to do a coarse and fine LD beam adjustment, then try line position again. I had to do this on a different model last week, and it worked.
    NEVER ASSUME ANYTHING
    • Jomama46
      • 2900
      "coarse" completes OK, but fine will not complete.
      sigpic
      A+; Network +; PDI+
      • mikadonovan
        • May 2008
        • 2931
        I had to run both 3 times to get a successful result, but it remedied the problem. Actually, the manual says to keep doing it until it works. Kinda cheesy, and as I said it is a different machine.
        • Jomama46
          • 2900
          OK, thanks for the input, Mika
          sigpic
          A+; Network +; PDI+
          • kannuki2
            • Feb 2012
            • 398
            SC 285 Line position adjust error - check and clean ID sensors
            SC 285 Line position adjust error - check for proper toner density for each color
            SC 285 Line position adjust error - replace the transfer belt
            SC 285 Line position adjust error - replace PCU(s)
            SC 285 Line position adjust error - replace laser unit assy
            SC 285 Line position adjust error - run SP2-111-3 (course) and SP2-111-1 (fine)
            SC 285 Line position adjust error - check if CMY transfer rollers are all up against belt
