I have a MPc4501 we just received into shop off lease that displaying the "SD Card Is Not Set Correctly" message. The only card in the machine is the VM card in slot 2. It appears they removed a SD card from slot 1 that may have had some programs on it. Reason I say this is because in user tools under Extended Features there are several programs under the "Add Program Startup Settings" that are grayed out and I can not install or uninstall.
Any thoughts? Any way to just turn off the notification?
