MP 7500/SR841 TSB#021R2
  • wester
    • Aug 2009
    • 113
    I'm working on a SR 841 finisher with a broken staple tray, the parts manual is referring me to TSB#021R2. Could some helkp me out with that is referring to? Thanks in advance.
  • Imprestik
    • Aug 2012
    • 297
    Re: MP 7500/SR841 TSB#021R2
    What you are going to need is the actual staple tray its self, then there is a bracket which connects to the back of it, screws to connect the bracket to the staple tray, a bearing and a drive shaft which is twice as long as the current one.
    If you still do not understand, refer to a SR5000 as all the modified parts are now located on these finishers.
    • wester
      • Aug 2009
      • 113
      OK Thanks, it broke right at that bearing, and it sounds like that bulletin was all the parts mods. Once again thanks.
