DSc445 SC385
  • Jomama46
    • 2900
    DSc445 SC385
    I can not get rid of this code. It points to a potential error. I cleaned the ID sensors and the result is 00 00 18. Again pointing to a potential sensor error. I called Ricoh and all they would tell me that I should follow the procedure in bulletin #32.
    So can someone send me this bulletin and/or advise me of the possibilities
    sigpic
    A+; Network +; PDI+
  • iMind
    Vacuum Cleaning Expert
    • Mar 2008
    • 1116
    On tessa now can´t find TB #32 and no related SC385.
    • cobiray
      Passing Duplication Xpert
      • Mar 2008
      • 1199
      TSB 32 refers to the color adjustment proceedure. PM me your email and I can send it to you.
      • Cipher
        It's not easy being green
        • May 2006
        • 1309
        Check the values of SP3107 002 / 004 / 006.
        If any of those values are over 200+ the LED reflective feedback is poor.
        According to your process control result the rear ID sensor reading (006) should have a high reading.
        This is normally caused by a dirty reflective roller where the LED signal bounces back off.
        (That's the roller directly opposite the ID sensors under the transfer belt).
        Or the transfer belt has marks/indents that pass in the path of the ID sensors.
        • Jomama46
          • 2900
          Thanks for the input. I'll post back when its fixed.
          sigpic
          A+; Network +; PDI+
          • iMind
            • Mar 2008
            • 1116
            I Kill you, this is da man. Its a pleasure reading your posts, very informative.
            Thanks Darren
            Keep on...
            stick it to da machine
            • Jomama46
              • 2900
              It pisses me off that Ricoh would send me off on a wild goose chase with that "follow the procedure in #32" jazz.
              Surely they would have a more informed opinion than that. As was stated, 385 has nothing to do with the color alignment.
              sigpic
              A+; Network +; PDI+
              • Fearless V K
                • 620
                Disassemble the transfer belt unit and thoroughly clean ALL metal rollers until they are shiny. Use a soft cloth moistened with water, and carfully wipe the inner surface of the transfer belt to remove any toner film which may have built up. You want the belt to be as transparent as possible. Clean the transfer belt cleaning unit completely, you may want to replace the cleaning blade, and brush as these components get worn out in the middle where the ID patches are developed on the transfer belt. Unless you have a bad ID sensor, or the transfer belt is fairly opaque from wear or damage, this will usually get the machine back to a happy state.
                Don't take that toner with me!
                • Jomama46
                  • 2900
                  Thanks for the input Fearless.
                  You see these suggestions in this thread are the kind of things Ricoh should have advised me.
                  F*ng A*s h*les
                  sigpic
                  A+; Network +; PDI+
                  • cobiray
                    • Mar 2008
                    • 1199
                    I'm not saying the support line is not a good thing, but I have personally and had some other techs given some dubious information. I still think they do more good than harm, but I do take it with a grain of salt. Besides, I've yet to see a tech who never made a mistake or mis diagnosis.
                    • rthonpm
                      • Aug 2007
                      • 2847
                      The old 'clean the roller' trick has been known forever now, but the big R has never released any kind of bulletin on it. The best way I've found to clean that roller is auto chrome polish. It takes off any kind of grime and leaves a good shiny reflective surface for the sensors.
                      • verderacer
                        • May 2008
                        • 158
                        Have anybody here tried using some scotch brite to clean rollers?
                        Ricoh & Microsoft may pay the bills but Un*x saves my ass every day.
                        MCSE/CCNE/ENS and other crap...
