Hey all,
I know there has been a bunch of posts in regards to SC555 on the Martini's and I have been implementing suggestions in regards to this but I have now noticed on all the devices I have changed the fusing temps, fusing idle on, I now seem to be getting a lot of SC552-03 on these devices.
Implementing these changes I have noticed the following,
SC555 no longer exists
Toner build up on the end thermistor is no where near as bad as it was before I changed all the recommended SP codes
Toner build up on the centre thermistor is far worse now than before hence the SC552
Any help would be greatly appreciated if there is some suggestions to get rid of these codes all together
Thanks.
Thanks.
