MPC 2500 Toner Problem
  • Tebow83
    • May 2009
    • 92
    Hi guys.
    having a problem with an MPC2500.
    The machine keeps saying add black toner - toner depleted.
    I changed the toner cartridge and machine kept saying the same.
    I then changed the toner pump to no avail.
    I replaced the k dev clutch and machine worked fine for a few hundred prints and now it has come back up with the add toner message.
    Any ideas where to go next?
    Thanks in advance.
  • JustManuals
    • Jan 2006
    • 9838
    Re: MPC 2500 Toner Problem
    Paul@justmanuals.com
    • sandmanmac
      • 3981
      Did you change the hose too? or just the toner pump? It Could be blocked.
      • DH1980
        • Mar 2009
        • 52
        I had the same problem and it was the ID sensors. They would give readings but not what they should be.
        • cdog530
          • Nov 2009
          • 66
          I have seen the dev drive gear (behind each drum) get worn down and not properly churn toner into the developer too.
          -C
          • Tebow83
            • May 2009
            • 92
            Cheers guys, will check those out tomorrow.
            Is the gear hard to change?
            • cdog530
              • Nov 2009
              • 66
              Just take out the image transfer belt, black drum and magenta drum to give you room...the gear is held on by an e-clip...does this machine have a high copy count? has the development unit been changed?
              -C
              • Tebow83
                • May 2009
                • 92
                -C
                Its at 500k black and the black dev unit was replaced.
                • redneckstylin
                  • Sep 2011
                  • 173
                  all firmware....
                  • stevie c
                    Originally posted by tebow83
                    hi guys.
                    Having a problem with an mpc2500.
                    Thanks in advance.
                    did u fit the pipe that comes with the pump,if you did then the next thing to look at is the dev unit.if you do the smc print out(5990-4)
                    you will see how many copies are on the dev unit.the dev unit is meant to be changed every 2 or 3 dev changes.hope this makes sence and is helpfull.good luck
                    • sandmanmac
                      • 3981
                      You obviously only read the original post and NONE of the rest of the thread
                      • OutlawTorn
                        • Aug 2008
                        • 189
                        -C
                        I have just had this fault and can't find this bloody gear in the parts manual, do you have the part number?
                        • cdog530
                          • Nov 2009
                          • 66
                          AB010368
                          • Dence
                            • 4
                            Originally posted by Tebow83
                            Hi guys.
                            Thanks in advance.
                            Try to clean (or it could be broken, so in that case replace) the "Toner End Sensor" (AW02-0185). Its the sensor that measures if there is toner coming out of the toner bottle, just before it goes into the hose to the toner pump. This also could do the trick if the toner pump is ok, the hose isn't blocked (just to be sure, vaccuum it out) and the MPC is still asking for new toner... Good luck!
                            • darius79
                              -C
                              I have had this problem and changing the worn out drive gear solved it. Remember to check on the K dev unit too, the developer inside can harden and cause the drive gear to wear prematurely.
