Ricoh MP2550 with SC672 Error
Re: Ricoh MP2550 with SC220 Error
I just closed out a call with a laser sync. error, and yeah it's an involved process when dealing with anything related to the laser. If you're not a trained tech, I wouldn't risk it, just words of caution there.
What I had found with mine, was relatively easy in retrospect. The machine I was working on had a bit of a toner blowout, what had basically happened was that some toner had managed to get inside the laser unit, this coated the optics inside and caused the laser to fail it's synchronization. We had to open up the laser unit and clean off the polygon mirrors inside that had a light coat of toner on them, once this was done and the unit reassembled, the code was cleared.
This isn't to say you are experience the same issue, it's just a starting point that may or may not help. There is a very real possibility that the synchronization detector has gone faulty on you, without knowing the history of the machine, it's condition and what not, there's little more I can offer you other than my own experiences that seem to be relative to your problem. Hope it helps.
Good luck.Comment
Re: Ricoh MP2550 with SC672 Error
As advice, you decide what to do."ALL WILL BE WELL" The battle cry that most inspires me to follow, from the DC's Comic character that I admire the most. And I feel satisfied with being better every day, and with using Gnu-Linux as my usual Operating System.Apologies for my English, it's not my mother tongue and I'm helping the translator.Comment
