MP2352 sc 230
  • Voltage
    • Jul 2008
    • 282
    MP2352 sc 230
    Hi guys
    I have a MP2352 that intermittently gives sc230.
    FGATE ON error
    The FGATE signal did not assert within the prescribed time.
    I have cleaned the registration sensor but it still gives the error. I am not to sure what the error means.
    Any ideas????
  • HP:guy
    • Feb 2013
    • 279
    Re: MP2352 sc 230
    No. Type Details (Symptom, Possible Cause, Troubleshooting Procedures)
    230 D FGATE ON error
    The FGATE signal did not assert within the prescribed time. (The BCU generates the FGATE signal and sends it to the LD unit when the registration sensor switches on.)
    231 D FGATE OFF error
    The FGATE signal did not go off within the prescribed time. (The BCU generates the FGATE signal and sends it to the LD unit when the registration sensor switches on.)
    • BCU IPU, Controller board harness loosen or broken
    • BCU IPU defective
    • Controller board defective
    1. Turn the main switch off and on.
    2. Check the connection between the controller board and the BCU IPU.
    3. Replace the BCU IPU.
    4. Replace the controller board.
    The new update.
    • Voltage
      • Jul 2008
      • 282
      Re: MP2352 sc 230
      • BCU IPU defective
      The new update.
      Going to be an expensive excersize :-)
      • wester
        • Aug 2009
        • 113
        Re: MP2352 sc 230
        Voltage, did you get this resolved? I have the same problem with one of my accounts.
        • Voltage
          • Jul 2008
          • 282
          Re: MP2352 sc 230
          I just reseated the ribbons cables and it seemed to work. Have not had any complaints yet. Lucky i guess.
          • Polarbear
            • Feb 2012
            • 1070
            Re: MP2352 sc 230
            Ricoh has also released a "fix" firmware for this, which has been incorporated in the latest version of firmware for this model. It would be worthwhile updating the firmware to the latest version to prevent that SC code from reoccurring.
            Press the GREEN button!!
