Ricoh Aficio 1075 throw out developer
  • m_donakov
    • 213
    Hi all i have problem with one 1075 machine, throw out developer from developer unit but just in the square i marked red, i tray change developer from other machine and was ok for some 500 copies and again the same problem. i don't know what to do this is unique machine we have over 50 1075 machines that we service and in all we use type 21 developer and same IPM toner ( compatible ) and this happens only on this machine if anyone can help please
    Mile
  • TonerMunkeh
    Professional Moron
    • 3865
    Re: Ricoh Aficio 1075 throw out developer
    Does the mag roller have the same defect on it?
    Hit it.
    • m_donakov
      • 213
      No the mag roller is clean and its look very good, no scratches on it i think on mag roller firs but it is look fine to me. I very confused if someone dont have other idea i will tray change mag roller tomorrow.
      • m_donakov
        • 213
        I changed mag roller 1000 copies was ok, after that again same problem any other solution please
        • Eric1968
          • 2458
          First of all, use OEM Toner. That aftermarket crap only gives problems. If you use OEM toner, you don't have to worry about the toner being the cause of copy quality problems. Vacuum out the DV-Unit, or replace the whole unit. Then pour in a fresh bag of developer and perform all adjustments.
            • 37533
            Eric1968 is correct about using the proper OEM toner. But more important the the toner is the developer. The proper developer for the 1075 is Type 24 not Type 21. Someone may have told you that you could use Type 21 for Type 24 and save money, but there is a different amount of developer in the bag.
            • m_donakov
              • 213
              Yes both of you are right, i use 900g developer here, but somthing else confused me. Same toner and same debeloper on other 40 machines work perfect.
              • kelvin3892
                • Mar 2010
                • 13
                Hi brother pls check Quenching Lamp
