hi,
I replaced controller board and NVRAM on MP 2852. The machines was being used as printer and scanner. After replacing the controller, I enabled 'on board NIC' from SP mode 5985. Scanner is enabled now but printer is not. Printer and Scanner SD card is inserted properly. Any ideas?
