SC 995-01 MP5002
  • katash
    • May 2010
    • 221
    [Error Code] SC 995-01 MP5002
    HELLO TO ALL!
    i replaced a controller board after the icons for the print/scan dissappered,put back the old nvrams in vain,went a step further and replaced the bcu and iob boards,I'm confused as the manual says its a bcu/nvram issue,please help i will really appreciate
    SC 995-01
    • Defective BCU
    • NVRAM Replacement error
    1. Install the previous NVRAM.
    2. Input the serial number with SP5811-003, and turn the main power switch off/on.
  • johnyb
    • Feb 2011
    • 167
    995 is a serial mismatch error, there are three areas where the serial is stored on this device and you need to check all three match up.
    I think you may habe to go into special sp to input.
    The novita one, as far as I am aware cant be adjusted.
    Good luck.
    • katash
      • May 2010
      • 221
      Re: SC 995-01 MP5002
      Good luck.
      thanks johny,
      i have inputed the serial how do u get to ssp as the manual has a level 3
      5811 MachineSerial
      002 Display Displays the machine serial number.
      003 BCU Inputs the serial number.
      005 FRAM Displays the FRAM serial number.
      • katash
        • May 2010
        • 221
        any more ideas
        • ptrflrs
          Glorified Parts Swapper
          • Dec 2010
          • 192
          access special sp mode by holding down [#] key then hit Copy sp on the screen. does it have postscript sd card? try it with it out.
          jesus loves you! (everyone else thinks you're an assh*le)
          street cred: CompTIA A+ & Network+ Certified; Konica Minolta Gold Seal x2,
          Konica Minolta Outward ASSociate, Ricoh, Sharp, Lexmark trained
          • johnyb
            • Feb 2011
            • 167
            pm sent
            • katash
              • May 2010
              • 221
              thanks for the input,but still cannot access SP 5811-5 FRAM to check the serial no. is this the novita?
              • ptrflrs
                • Dec 2010
                • 192
                u mean nvram? FRAM might be "fixed ram" but not sure.
                • katash
                  • May 2010
                  • 221
                  me too not sure i've even replaced the nvram from another new mcn and input serial no. but to no avail,in a dilemma!
                  • katash
                    • May 2010
                    • 221
                    DONE!!!
                    just realised you have to replace both eeprom and nvram at the same time and input serial no.
                    • abderazakaf
                      you have first to enter SSP mode you hit first all clear key yellow one then 143 then C key twice at that you can acccess & go sp 5811-002 & 003 then change the serial number but FRAM or NOVITA you can't change it.
                      best regards
                        • 36831
                        best regards
                        You must be a grave robber as this thread has been dead and buried for over a year. In the future, check the date of the last previous post to a thread before you add an unnecessary comment. You will find you will get better treatment from us old farts if you do that.
