Aficio 3510SP, op panel
  • copycart
    • May 2009
    • 97
    [Misc] Aficio 3510SP, op panel
    Has anyone had to replace the keytop on the 3510 small MFP. The manual seems to take you through removing the scanner. was wondering if there was an easier way
  • Eric1968
    • 2458
    Re: Aficio 3510SP, op panel
    You need to remove some screws at the under side of the scanner, so you have to remove the scanner and the ADF. I think replacing the operation panel on this machine isn't a problem. I've seen worse...
    • copycart
      • May 2009
      • 97
      Thanks, I take it you done it before because of the numbers wearing off the keys as well. Pretty quick as well
