c-6501 with a sc670
  • Sharptech0892
    • Aug 2011
    • 78
    c-6501 with a sc670
    copier will not let us go into service mode, we've tried clear mode+107+clear/stop hold for 5sec but machine doesn't go into service mode?
  • rsyarcia
    Hair Straightener Tech
    • 711
    Re: c-6501 with a sc670
    have you tried updating the firmware?
    Nobody is perfect..
    • ruben
      The New Guy
      • Oct 2012
      • 1203
      Probably has service lock turned on, the customer will have to disable it to allow you into SP mode. You can do it yourself if you know the admin login, and disable it under User Tools.
      • Iowatech
        Not a service manager
        • 3930
        Or it could be that one or more of the switches on the op panel PCB have been smashed flat. It would be a good idea to try the service lock or firmware, but if you have a working machine you might take the op panel from that along as well and try swapping the op panels first.
        • JustManuals
          • Jan 2006
          • 9838
          Paul@justmanuals.com
