Ricoh Aficio 1022 Doesn't print
  • Zoollanderhu
    • Aug 2010
    • 76
    Hi All!
    First of thank you for looking my thread.
    So before I tell my problem I must say I'm not really familiar with Ricoh, mechanically not too different and tricky, I 'm rather familiar with Canon and HP and Kyocera (Utax and Triumph also) .
    So my problem is the following:
    I've got a Ricoh Aficio 1022 wich had printed but the webpage's password wasn't the deafult, I looked after on the forum to resolve it. I found out how to login into sp mode and SP5801-11 NCS clear.... hurrayyy it resolved the password problem and I can configure over the webpage.
    So now I can ping the IP address of the machnine =OK and also I can see the webpage=OK, DHCP works so it seems the connection is fine, but the printer side doesn't work.
    I try other drivers pcl5-6 rpsc, nothing happend.
    What's the matter?
    What should I look for?
    Thank you in advance!
  • johnyb
    • Feb 2011
    • 167
    Does it have a print scan option installed?
