mp5500 print problem
  • tonyd
    • Jul 2025
    got a weird fault on 2 of these machines on different sites. every now and again customers complain of intermittent jobs in the print queue disappearing and not printing out. tried all the usual suspects ie drivers, port settings, machine settings(user codes etc). even tried swapping the network card on one! any ideas??
    tony
  • unisys12
    • 489
    I think you will have to narrow this one down a little more.
    Which customers are having this issue and of those which application are they using?
    sigpic
    The first law states that energy is conserved: The change in the internal energy is equal to the amount added by heating minus the amount lost by doing work on the environment.
    • cobiray
      Passing Duplication Xpert
      • Mar 2008
      • 1199
      Do you have the user codes enabled? If so and you send a job with out the code, or an invalid code, it will be deleted from the queue and not printed.
      • tonyd
        hi
        The customers vary and they are printing normal word or pdf documents. it cant be narrowed down to any particular document. it is VERY intermittent and the customer has lots of the 5500's dotted about with no problems. User codes arent used. These machines are only about 3 months old in each customer.they use windows server 2003 and desktops are xp.
        • cobiray
          • Mar 2008
          • 1199
          One item to try is the print driver. If you are using PCL 5, try the PCL 6 driver. I've also had issues with using both drivers on the same network, so if you are using both maybe try un sharing one of them. If all that fails, try loading the print driver locally on the pc's.
          Also, you might try updating the firmware on the MFP.
          • tonyd
            hi
            yep done all the basic stuff ie drivers, firmware, tried usint smartnet monitor ports. still no good
            • cobiray
              • Mar 2008
              • 1199
              I'd have the users print to another location (another 5500) or swap the box out from another location changing the I.P. and other info. Sounds like a network issue, or possibly PIBKAC.
              • paulg
                • Jun 2007
                • 278
                Have you dropped the network speed to 10mb/s.
                Not very useful with a high speed machine but quite often cures the problem on various networks for us.
                • tonyd
                  hi
                  i have tried mostly everything including network speed. swapped ip addresses and even cards. moved one of them onto a different network. just an update i went back today with firmware that was released 14/05/08 so fingers crossed
                  tony
                  • cobiray
                    • Mar 2008
                    • 1199
                    tony
                    So when you moved the machine to a new location the dropped prints followed the machine?
                    • tonyd
                      nope
                      problem still happened after move
                      • Jomama46
                        • 2900
                        I think you have to eliminate the print server (at least for testing) and install the drivers on the affected workstations. Server 2003 had some printer issues for sure.
                        sigpic
                        A+; Network +; PDI+
                        • tonyd
                          hi
                          problem is 2 of the machines are on server 2003 with 200 other printers and cant load drivers locally as users use roaming profiles. the other machine is on small business server so at first thought the isa server was stopping snmp broadcasts. added this to the exclusion list with no joy.
                          • Jomama46
                            • 2900
                            Me and Johnny will give this some thought tonight.
                            sigpic
                            A+; Network +; PDI+
                            • morocas
                              Senior Tech Australia
                              • Aug 2007
                              • 11
                              Having the same issue and have done virtually the same repairs. Mine prints the jobs when the machine is powered off/on.
