SC started out as a 598 (I believe) Re-formatted the hard drive cleaned the connectors and now its throwing a SC 672 which is a controller board error I think.
MP C4502 SC 672
Re: MP C4502 SC 672
This attached troubleshooting doc was recently published. See if it helps....Attached Files -
Re: MP C4502 SC 672
Have you disconnected the HDD and started the machine without it? HDDs are dodgy at the best of times and a failed one can stall your machine into "PLEASE WAIT" that feels like forever, and then BANG the SC code!
If it starts without the drive, remove the HDD and format with the help of a pc. Then re-install in machine and see if it starts.
If it does, then you can reformat it with SP mode.
If the pc wont format it - the disk is cooked and needs replacing.Press the GREEN button!!Comment
