Ricoh MPC 4502
  • PinevskiS
    • Jul 2009
    • 283
    [Error Code] Ricoh MPC 4502
    I have a Ricoh MPC 4502 copier and a screen appears that photoconductor unit is not set correctly (MAGENTA UNIT).
    This problem occur during the operation of photocopiers. We created a new TD sensor replacement, but the problem is not resolved.
    Does anyone have any idea.
    Thanks.
    B.R.
  • Llama God
    • Mar 2009
    • 1353
    Re: Ricoh MPC 4502
    Originally posted by PinevskiS
    Thanks.
    B.R.
    If it's not set correctly, is it a magenta PCU or have you modified a black one to go in? The issue is that the machine cannot see it at all. Also, have you plugged in the connector between the dev unit and PCU?
    • JustManuals
      • Jan 2006
      • 9838
      Re: Ricoh MPC 4502
      Paul@justmanuals.com
      • PinevskiS
        • Jul 2009
        • 283
        Re: Ricoh MPC 4502
        Magenta Drum is original which came with the machine.
        I checked all these things but no effect. The question is which board is responsible for controlling the TD sensor.
        Thanks.
        • Llama God
          • Mar 2009
          • 1353
          Re: Ricoh MPC 4502
          No it isn't, it's nothing to do with the TD sensor if it says that it's not set correctly.
          If you're convinced that it is though, I'd have to assume that you're an engineer of sorts and, as such, you can read a manual. If you don't have one, Paul will be able to help you out.
          • Llama God
            • Mar 2009
            • 1353
            Re: Ricoh MPC 4502
            Fine, I'll save you the bother, it's the RTFM board.
            • Eric1968
              • 2458
              Re: Ricoh MPC 4502
              I never replaced a TD-sensor in these machines, and as far as I know you can't order a separate TD-sensor. And as Llama God says, this has absolutely nothing to do with the TD-sensor.
              • Llama God
                • Mar 2009
                • 1353
                Re: Ricoh MPC 4502
                Thanks chap, I was beginning to have my doubts.
                • turbojetboy
                  • Aug 2009
                  • 279
                  Re: Ricoh MPC 4502
                  Thanks.
                  B.R.
                  I had exactly this problem recently, low volume mc showing replace photoconductor (MPC4502). I replaced the toner tube and bingo - message gone.
                  I think it may be either a firmware issue or perhaps a problem with the toner tube connectors which look like they are actual contacts now rather than RFID.
                  Try a new toner.
                  • PinevskiS
                    • Jul 2009
                    • 283
                    Re: Ricoh MPC 4502
                    Try a new toner.
                    I replace the toner magenta ,but no effect, still occurs photoconductor unit is not set correctly (MAGENA DRUM)
                    Thanks.
                    • Llama God
                      • Mar 2009
                      • 1353
                      Re: Ricoh MPC 4502
                      The connector for the PCU on the rear frame of the machine is possibly damaged. I'd try another PCU in it first - swap it with the cyan or yellow to fault find.
                      • Debs1964
                        • Oct 2010
                        • 1693
                        Re: Ricoh MPC 4502
                        This just made me laugh out loud
                        There are 10 types of people in this world, those who understand binary maths and those who don't
                        • Llama God
                          • Mar 2009
                          • 1353
                          Re: Ricoh MPC 4502
                          Idiots.
                          I love the fact that your comment got a "like" whereas mine did not. You have fans. Girls have an unfair breast advantage.
                          I love gin.
                          That is all.
                          • Debs1964
                            • Oct 2010
                            • 1693
                            Re: Ricoh MPC 4502
                            Idiots.
                            I love gin.
                            That is all.
                            You have 2 likes for your comment, so stop whining.
                            I love having an unfair breast advantage, and I know how to use it
                            • Tonerbomb
                              AutoMajical Resolutionist
                              • Feb 2005
                              • 2589
                              Re: Ricoh MPC 4502
                              Idiots.
                              I love gin.
                              That is all.
                              Personally I enjoy the unfair breast advantage women have, but if your feeling inadequate there are medical ways you can use to even the playing field........
                              Mystic Crystal Revelations
