MPc2050 with java
  • iMind
    Vacuum Cleaning Expert
    • Mar 2008
    • 1116
    MPc2050 with java
    sigpicWe can all Win, but at the end we all loose. Save the greyhound
  • rgcs1
    Systems Intergrator
    • 69
    Re: MPc2050 with java
    Try this document and see how you go.
    Pages from PCC Handout 20 v1.2.pdf
    • Moza
      • 232
      Originally posted by iMind:378829
      null
      All the files are within the paper cut directory in program files, its been a while since I last installed it but im sure you will find an install guide there too
      • iMind
        • Mar 2008
        • 1116
        • iMind
          • Mar 2008
          • 1116
          [ATTACH]22108[/ATTACH]
          Thanks for the pdf, but what I need to know is if I need to create a special folder no the SDcards root or something like that.
          • iMind
            • Mar 2008
            • 1116
            512 Mb needed for the application to work, this means the machine must have in total 1Gb. Thanks anyway...
