4018D Setting Up Print from USB
  • Solotime
    • 223
    Trying to get a 4018D printing for a customer. They have the ethernet and USB card in the machine but it does not seem to see the machine from the usb port. Does the USB option need to be "turned on" from service mode? Is there anything else that normally needs to be done to print via USB cable on this machine?
  • mikadonovan
    • May 2008
    • 2931
    Re: 4018D Setting Up Print from USB
    No, the usb card is plug and play. Data rates may be adjusted in SP 5844. Maximum usb cable length is 5 meters. Make sure SP 5907(plug and play) is registered.
    NEVER ASSUME ANYTHING
    • blee
      Technical Trainer
      • 54
      I don't think this model has the nic/usb enable SP but you could check. It would be SP 5-985-002 for USB setting. Make sure it is a 1.
      • sandmanmac
        • 3981
        If the usb is not functional, I'm just curious why you don't connect it to the NIC if that's working?
        • Solotime
          • 223
          I got it printing. Had to install "usb printing support" on their PC. Now they called back and want it to scan too!
          Can this thing scan via USB? If not then we will have to use Ethernet and scan to email. Which is an issue with them as there network is locked down tighter than anything I have seen as we had issues with other machines on their network. Hopefully we can scan using USB tho?
          • Llama God
            • Mar 2009
            • 1353
            In short, no.
