SC-819 MP 5000
  • edwin206
    • Mar 2012
    • 36
    [Error Code] SC-819 MP 5000
    Hi,
    It is an AFICIO MP5000 unit with constant SC-819.
    Machine stops at "PLEASE WAIT " state for 5 minutes approximately and then shows SC819.Is there any solution for the problem .I have tried to avail its boards locally but nothing is available.
    Please give some solution to get rid of it.
    No fax unit unit is in machine and no print controller etc.I am very new to these models.
  • sandmanmac
    • 3981
    Re: SC-819 MP 5000
    Any more info on what led to this condition? Was it working fine at its current location, or is this a machine you have come across that may have had other options installed that have since been removed? You might try unplugging the HDD and booting up the machine. If it boots up normally (however with limited functionality), try reformatting in SP mode, otherwise replace.
    All that said, a little more info would be helpful
    ALso...is it an MP5000B or just a straight MP5000?
      • 37532
      Re: SC-819 MP 5000
      Since SC-819 is almost always a problem with the HDD, it is probably not a 5000B. If it has a FAX option but no HDD, it is bad RAM. If it a 5000SP, disconnect the HDD. If it is a 5000SPF, remove the fax option and disconnect the HDD. If it will boot, either replace the HDD or if it did not have a HDD, replace the RAM.
      • muaazgujjar
        • 67
        Re: SC-819 MP 5000
        It is MP5000 B
        • TonerMunkeh
          Professional Moron
          • 3865
          Re: SC-819 MP 5000
          Controller board has expired, you'll need to replace it. Also? Is anyone else finding it odd the response has come from a completely different person?
          Hit it.
          • Bantams
            • Jun 2012
            • 603
            Re: SC-819 MP 5000
            Doesn't 819 occur when the serial number on the nvram doesn't match the one on the bicu ram?
            I'm Sure I've had this before and had to re input the serial number in a SP manually.
              • 37532
              Re: SC-819 MP 5000
              Originally posted by edwin206
              Hi,
              Prior to the SC-819 first occurring did you or anyone else try to enable the network interface using SP 5985-001 without first installing the additional memory? If so, you will need to install the additional 256K of memory, Memory Unit Type G. If the addition memory has been installed, it could be not seated properly or bad.
              • JustManuals
                • Jan 2006
                • 9838
                Re: SC-819 MP 5000
                This Parts & Service manual can now be purchased for $12.77 and downloaded immediately after payment from:
                Paul@justmanuals.com
                • Moza
                  • 232
                  SC 819 on this machine is very common and pretty much always the controller occasionally may also be be the BICU.
                  • edwin206
                    • Mar 2012
                    • 36
                    Re: SC-819 MP 5000
                    Hi,
                    I am trying to fix the unit .Machine's physical condition is as under. I interviewed the operator(accused one).
                    The machine is without hard disk and print option etc.It's a simple copier MP5000B and the problem occur during a sudden switching of light.
                    I could not understand that of serial number of BICU and NVRAM.
                    Trying to enter SP mode through SP mode but did not do so. SC-819 on display and unit stand still.
                    I am very obliged to the seniors for very precious guidance. Thanks to all and still wandering for the fix.
                    • TonerMunkeh
                      Professional Moron
                      • 3865
                      Re: SC-819 MP 5000
                      The fix is - THE CONTROLLER BOARD NEEDS TO BE REPLACED.
                      Hit it.
                        • 37532
                        Re: SC-819 MP 5000
                        If none of the other suggestions have corrected the problem, then you will have to go to the expense of a new controller. Order the correct board as there four different model controller boards and BICU boards. See TSB-006 for identification.
                        If it is the controller board, make certain that the customer knows that the main power should never be turned off if the operation switch is On or Blinking. According to TSB-038 Reissue, the Basic model of this line can damage the controller board if not turned off properly.
                        • cleardata
                          • Jul 2011
                          • 137
                          Re: SC-819 MP 5000
                          gotcha!!!
                          • ajim shine
                            • Apr 2014
                            • 6
                            Re: SC-819 MP 5000
                            i got same problem and need to know how you slove this problem..this problem come same like you story.
                            • sandmanmac
                              • 3981
                              Re: SC-819 MP 5000
                              There are 2 pages of suggestions! Do you care to tell us what, if anything, you've done?!
