Re: SC-819 MP 5000
Doesn't 819 occur when the serial number on the nvram doesn't match the one on the bicu ram?
I'm Sure I've had this before and had to re input the serial number in a SP manually.
SC-819 MP 5000
Re: SC-819 MP 5000
Controller board has expired, you'll need to replace it. Also? Is anyone else finding it odd the response has come from a completely different person?Leave a comment:
Re: SC-819 MP 5000
It is MP5000 B
Any more info on what led to this condition? Was it working fine at its current location, or is this a machine you have come across that may have had other options installed that have since been removed? You might try unplugging the HDD and booting up the machine. If it boots up normally (however with limited functionality), try reformatting in SP mode, otherwise replace.
All that said, a little more info would be helpful
ALso...is it an MP5000B or just a straight MP5000?Leave a comment:
Re: SC-819 MP 5000
Re: SC-819 MP 5000
SC-819 MP 5000
It is an AFICIO MP5000 unit with constant SC-819.
Machine stops at "PLEASE WAIT " state for 5 minutes approximately and then shows SC819.Is there any solution for the problem .I have tried to avail its boards locally but nothing is available.
Please give some solution to get rid of it.
No fax unit unit is in machine and no print controller etc.I am very new to these models.
