SP5210RS Disable Embedded Software Architecture
  • jmandassociates
    • Sep 2008
    • 186
    Trying to figure out how to disable this screen pictured at startup. Please install/start the extended feature in [Extended Feature Settings]. Is there a way to turn it off of something to uninstall. Thanks for any help.20131004_142157.jpg
  • ruben
    The New Guy
    • Oct 2012
    • 1204
    Re: SP5210RS Disable Embedded Software Architecture
    It is under User Tools -> System Settings, there you can change the start-up priority. Most likely it was set to start PaperCut or another accounting application at one point. You can also uninstall any Java applications by logging into the web manager, it should also state there what application was meant to start.
    • jmandassociates
      • Sep 2008
      • 186
      Great thanks that worked.
